Results 1 to 3 of 3
Thread: Engine mounting bolt??????
    chalky4's Avatar
    Nov 2008
    Newport Pagnell
    At last my engine bars arrived from M&P, instructions a bit hit and miss but I finally got them fitted, if only I was an octopus when it came to fitting the top plate to the frame!!
    Anyway the bolt they supplied to replace the lower front engine mounting bolt isn't long enough, only 100mm, so I need to to get a longer one. I think its an M8 130mm I need, does that sound right?
    Also can you advise me does it have to be hi tensile as its a mounting bolt or will any do?
    Chalky
    Re: Engine mounting bolt??????
    Take it to your local breakers and match it from their selection, they must have one which will fit.
    chalky4's Avatar
    Nov 2008
    Newport Pagnell
    Thanks Stumpy, good idea certainly worth a try
  1. Top bolt with Airscrew rd04
    Last Post: 12-08-08, 03:04 PM
  2. Replies: 0
    Last Post: 27-04-08, 05:49 PM
  3. Bolt Size
    By cafe650 in forum Dominator / FMX
    Last Post: 14-09-07, 07:43 PM
  4. Zega mounting bolt
    Last Post: 30-05-06, 08:34 PM
  5. Nut and Bolt chain adjusters anyone?
    By Mutley in forum Africa Twin
    Last Post: 08-01-06, 06:09 PM
