Hi Guys
Just finished doing my steering head brgs today on My 99 xl600vx.
The old standard ball races were so shot it would only go in a straight line!
Got a set of taper rollers complete with seals from Wemoto and set about the job..
Stripped off the front fairing uppers, wheel out and bars off dropped out the fork tubes and thought right lets knock the inner races out before bedtime
Not a chance! ive done a few bikes over the years and its a doddle normally the bearing race is a good bit smaller in diameter than the frame tube and you just use a piece of bar and drift them out. Not this one
The bearings only show you about 0.5 of a mm as a lip to put your drift against.
I was in two minds about going out and buying an expanding bearing puller but being skint.. decided to percy
So after trying different chisels, drifts, bent bits of steel bar ground to suit the diameter of the inner tube etc etc
I finally found a length of stainless tube 38mm diameter which just went through the top race so by angling it hard up against the edge of the inner frame tube and twating it on the angle with the hammer managed to get the brg to move just a tiny bit. 15 mins of tapping turning muttering etc and it finally popped out.
What a job
Once they were out replacement was a breeze and by the way a piece of 22mm copper pipe makes a great drift for putting the bottom bearing onto the yoke.The old races you took out make good protectors for knocking the new races back in.
Once in they feel great and dont seem as tricky to set the correct torque before you tighten down the head nut.
Done a few miles this weekend before the weeks commute starts tomorrow and all seems fine
Another maintenance task done.. whats nextclutch I reckon.
Sorry its a bit war and peace!!
