Results 1 to 3 of 3
Thread: Tubless adaptation
    ©-©'s Avatar
    ©-© is offline Xi dwejjaq member
    Sep 2008
    Middle©
    Tubless adaptation
    I'm told that it is possible to adapt, and make air-tight, spoked TA wheel rims to safely accept tubeless tyres.
    Any of you lot done it and done away with the tubes?
    Any opinions as to efficaciousness of such an adaptation?
    Re: Tubless adaptation
    There is a rim that can use tubeless tyres on spoked wheels but I do not know if they come in the sizes needed for the TA.
    Aberdeen
    I have been using BT45 road tyres on my TA700 for almost a year now without problems..
    The tyre garage said it was fine to use an innertube with the BT45.
