Results 1 to 2 of 2
Thread: Lower front engine mounting bolt
    chalky4's Avatar
    Nov 2008
    Newport Pagnell
    Hi all,
    Can anyone tell me what size the lower front engine bolt size is for an 88 TA. As previously said got my crash bars and the supplied bolt wasn't long enough, i need a 130mm but don't know the diameter, been to the scrappy (as suggested) but no joy, going to have to by one but need size, is it an M8 and does it have to be hi tensile?
    Re: Lower front engine mounting bolt
    I think it is high tensile.
    As a rough guide the nut is 4mm bigger than the shaft so an m8 has a 12 head.
  1. Seized in engine bolt.
    By Andyxl in forum XL
    Last Post: 21-04-09, 03:01 AM
  2. Engine mounting bolt??????
    By chalky4 in forum Transalp
    Last Post: 13-04-09, 08:18 AM
  3. Replies: 0
    Last Post: 27-04-08, 05:49 PM
  4. Zega mounting bolt
    Last Post: 30-05-06, 08:34 PM
  5. Replies: 0
    Last Post: 28-10-04, 09:45 AM
