Results 1 to 10 of 15
Thread: Temperature Guage Not Working
    Apr 2009
    Galway, Ireland
    HIya, just got a TA and the temp gauge is not workgin - a friend of mine suggested i could get one that would simply attach to the handlebars and somehow have a connection to the engine so i know whats going on down there - any suggestions? As you can guess from the question, i'm not terribly mechanical - any help apprecitaed. TB
    jasonbc's Avatar
    Camborne, Cornwall
    Re: Temperature Guage Not Working
    Quote Originally Posted by brownetara View Post
    Is the guage thats at fault or the sensor?? if the sensors faulty the guage won't/ maynot register anything. May even be the wiring between the too you'll have to have a look at it. NO point buying another gauge then finding out you don't need it
    GASGAS TXT250 PRO 2006
    Apr 2009
    Galway, Ireland
    I'm pretty sure it's the gauge not the sensor as the fans are coming on ok? But to get a new gauge i'd have to get a whole set of clocks (about €600) so trying to find a cheaper option so i can keep an eye on the temp. TB
    jasonbc's Avatar
    Camborne, Cornwall
    TRAILTCH DASHBOARDS COME WITH SENSORS FOR WATERCOOLED ENGINES YOU COULD CHANGE THE COMPLETE DASHBOARD TO A TRAILTECH IF DESIRED FOR AROUND £50 AND THAT WOULD SHOW YOU ENGINE TEMPERATURE.
    Trail Tech Products the European home for Trail Tech
    Apr 2009
    Galway, Ireland
    Quote Originally Posted by jasonbc View Post
    Will give them a go - thanks, Tara
    raymo's Avatar
    aberdeenshire Scotland
    I have a Trailtech fitted to the XLV, with the temperature sensor for an air cooled motor, ( its attached to a copper washer that goes under the spark plug. ) the water cooling sensor is a short bit of pipe that goes in the water circuit.
    I have the Trailteck vapour.. it measures speed-rpm as well as temperature they are about £70-80, they also have amber & red leds that can be programmed for alarms and gear shift lights
    its nice kit and reasonably priced
    bit more than a temp sensor though... I would not bother really, if the fans are ok.. the 'working' sensor on an Alp hardly moves any way..
    but if you want piece of mind and a few more toys....
    http://www.trailtechproducts.co.uk/ added the link
    XRV 650R RD03 1989
    The Longest Day Rider 6
    Apr 2009
    Galway, Ireland
    Quote Originally Posted by raymo View Post
    I think for the sake of £70/80 its probably worth it - are they easy enough to fit? Tara
    raymo's Avatar
    quite easy to fit, though you will need to mess with the cooling hoses to get your sensor in.
    the revs are picked up by just wrapping the revs red wired 5-10 times around a plug lead.. if you want speed you just mount a wee magnet on the disk ( they suppy a replacement disk bolt that has a built in magnet too ), the magnet triggers a sensor, you mount on the forks..
    it quite simple and you get all the bits and a bar mount too
    ohhh and the dashboard, is just that... Its a clipon external cover that allows you to wire in warning lights.. you will only need that if you are replacing your clocks completely, think there is a pick on mine in the gallery..
    found it not a good pic but gives an idea
    XRV 650R RD03 1989
    Apr 2009
    Galway, Ireland
    Cool, will keep looking on the net in case i can find a simple temp gauge/thermostat option as it would probably be easier but at least theres options out there - thanks again for all the help! ANd if you;re ever over this way, make sure you give me a shout. TB
    raymo's Avatar
    will be passing through on the longest day
    take care... dont worry, as long as there is water in it and the fan works.. the Alp will never overheat
    XRV 650R RD03 1989
  1. Ambient Air Temperature Gauge
    By campagman in forum Mechanical Advice
    Last Post: 06-05-08, 10:31 PM
  2. Coolant temperature
    By jay in forum Africa Twin
    Last Post: 14-06-07, 01:41 PM
  3. water temperature
    By french tony in forum Transalp
    Last Post: 28-04-07, 11:38 PM
  4. Oil Temperature Guage
    By boomboom in forum Dominator / FMX
    Last Post: 14-09-06, 10:15 AM
  5. XRV650 Running Temperature?
    By BobA in forum Africa Twin
    Last Post: 04-03-05, 06:10 AM
