Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: what type of chain lubricant?
    deskjetian's Avatar
    deskjetian is offline Senior Member
    Apr 2009
    The Midlands
    The owners manual for my XL700V says that I should use sae 80 or 90 gear oil for manually lubricating the drive chain, yet 2 of my local Honda dealers say I should use something like silkolene.
    I was wondering what you use ?
    russt1969's Avatar
    russt1969 is offline Long Way Home 2010
    Aug 2008
    Cheam, Surrey.
    Re: what type of chain lubricant?
    Scottoiler & Silkolene
    Austin's Avatar
    GARSTANG
    Quote Originally Posted by deskjetian View Post
    umm,they probably would wouldn't they
    EP90 or whatever is fine for me and is what I run through my scotoiler at the moment as I had very old nearly full 5litre can. It does smell though.
    Most chains are o ring sealed, the oil is only to put a film between the metal and stop the o rings drying out so any oil is ok.
    MandoBear's Avatar
    Herefordshire, England
    I use EP120 (from an agricultural suppliers) cut with a bit of 10w/40 semi synth engine oil to get it to flow a bit better in winter - through a Loobman oiler. Cheap as chips - and effective. EP (extreme pressure) oils are very effective in reducing friction even in very thin films.
    Mar 2007
    Bridport Dorset
    i use a Scottoiler but every so often(once a month?) i put bike on centre stand and drown the chain in whatever oil is in my oilcan. it all helps.
    PerfectStranger's Avatar
    PerfectStranger is offline Senior Member
    Mar 2008
    Lisbon, Portugal
    This one here. Does not make a mess on the rear rim.
    deskjetian's Avatar
    Apr 2009
    The Midlands
    Thanks for all your replies.
    I've only had the bike 1 month (from new) and I started off using just ordinary car engine oil, once a week. Asking the dealers just confused me and I ended up buying some silkolene. It seems ever so thin when applied though.
    Ian.
    raymo's Avatar
    aberdeenshire Scotland
    Spot on.. all the oil is for is to stop the o rings drying out,
    if your going to give your chain a good going over in addition to an an auto oiler, then slap on any oil you have, but best after a run when the chain is warm, as the oil has a better chance of getting where it's needed
    messy things chains... that why I love the XLV
    XRV 650R RD03 1989
    The Longest Day Rider 6
    Orinoco's Avatar
    Orinoco is offline Womble
    Apr 2008
    Rochester, Kent, UK
    I use Castrol Chain Wax, once a week sprayed on the chain just after I get back from work, when it is nice and warm. I try to aim it at the o-rings from both sides of the chain.
    I also clean the chain off once every couple of months to get rid of the road grime and dust that sticks to the lube'ed chain to stop it from from damaging the o-rings
  1. model type
    By super@ in forum Africa Twin
    Last Post: 03-08-08, 06:37 PM
  2. New type of fmx??
    By Palmer in forum Chatter
    Last Post: 03-05-08, 12:21 AM
  3. oil type and grade?
    By johnniep in forum XR
    Last Post: 08-03-08, 06:15 PM
  4. Oil Level & Type
    By Martin K in forum Transalp
    Last Post: 06-03-08, 10:18 PM
  5. A different type of stand!
    Last Post: 02-03-05, 10:24 AM
