Results 1 to 4 of 4
Thread: Rear Shock
    Cabby's Avatar
    Cabby is offline SOTGATT
    London/Surrey
    Rear Shock
    Just cleaning round after removing the engine....
    Pulled a broken piece of rubber/plastic ring out from the rear shock spring....
    Is this some sort of seal......if so...what now.....can it be replaced easily
    I was thinking of undoing all the suspension links and regreasing them anyway....
    Nothing's ever straight forward eh........
    Re: Rear Shock
    Are you sure the shock is complete, including the o ring that is used to stop the damper from hitting the stop.
    Cabby's Avatar
    London/Surrey
    Re: Rear Shock
    It's some sort of dust seal on top of a sleeve at the bottom.....I've glued it back together, then siliconed it in place.....OK for now.
    Took the rear shock apart and buffed it up a bit and greased the suspension link.
    I don't want to get too carried away as I need to fit the engine and find out if it's OK, but I don't want to ignore stuff I can do easily whilst the engine is out.
    Re: Rear Shock
    You could have popped down to Tippets and they may have had a new replacement. It does not look like it would cost too much and it is a prudent thing for suspension parts.
  1. Rear Shock
    By cabbage2404 in forum Mechanical Advice
    Last Post: 08-02-08, 07:30 PM
  2. Rear Shock ?
    By GIDEON in forum Africa Twin
    Last Post: 28-01-08, 06:47 AM
  3. rear shock TA
    By bikecrazy100 in forum Transalp
    Last Post: 24-11-07, 08:03 PM
  4. Rear Shock
    By TAY in forum Transalp
    Last Post: 01-01-07, 12:58 PM
  5. Rear Shock
    Last Post: 14-08-06, 05:49 PM
