MPG
Hi,
Have a 98 TA, 22,000 miles, runs well but think I should be getting more MPG, lots of town riding but only getting 130 miles till it's time to fuel up, any idea's..........?
Regards
Nigel
Re: MPG
Check the air Filter is not blocked.
How many Litres do you put in?
Re: MPG
Yep, check air filter.
Also check choke cables/plungers are free.
I dont get much more from my 96 Alp. (it does have to work hard though
Re: MPG
Hi all,
Air filter is fine and bike running great, i have backed of the mixture half a turn and still runs fine, I am going from Dorset to Devon Sunday so will see if she is better on a long run and will not go to mad....!
Nigel
Re: MPG
My 650's fuel gauge drops quite quickly after 90 miles but I find it averages 90 to 10 MPL if I thrash it on a long bimble it can get up to 12MPL.
- You may not post replies
- You may not edit your posts
Forum Rules
