Results 1 to 10 of 10
Thread: SERVICE
    scutle's Avatar
    scutle is offline 2001 Transalp, 1992 nx650
    Apr 2009
    Lisburn
    SERVICE
    I had a look last night to see whats involed in changing Plugs & Air Filter on my 650 T/A it look like lots of striping whats involed???
    Lutin's Avatar
    Galway
    Re: SERVICE
    Quote Originally Posted by scutle View Post
    1) Remove the fairing. Not as difficult as it sounds.
    2) Remove the seat. Easy peasy.
    3) Remove the tank. There is the sender unit connection that lives under the left frame rail near where the nose of the seat would be. Don't go mad, you can unplug it, you just need to be careful.
    4) Unscrew the several large screws to get into the air filter cover to replace the filter.
    5) Put in new filter after cleaning out the housing and put all the screws back.
    6) Replacing the tank is a bit tricky as you have to line up the overflow and breather pipes. A block of wood to hold up the tank makes life a little easier.
    7) Do all the plugs except the front left one. These are the easy ones.
    Unbolt, but do not remove the left hand radiator. This makes it easier to remove and replace the front left spark plug. Remember to re-fasten the radiator once you've finished.
    9) Do the oil and filter whilst you're there.
    Oh, and get the Haynes manual - you'll save loads of time by using it. Maybe your local library can get hold of one for you?
    Or bring it down to Galway.......
    scutle's Avatar
    Apr 2009
    Lisburn
    Re: SERVICE
    CHEERS there seeems to be 2 large push fittings 1 on each side of the fairing are these a BO**OCKS to pull out can you crack the fairing easy, have you to remove the 2 small peices top & bottom at the head light? I'll give it a go, my vmax is alot easier to service!!
    Alba's Avatar
    Alba is offline Senior Member
    Fife, Scotland
    Re: SERVICE
    Not sure the pieces you refer to top and bottom of the light? I have to take the fairing off in a oner as the screws which allow you to separate each fairing are fecked
    Think about putting in a K&N you will not need to replace it again and only have to go in once a year to clean it out
    Also take it easy with the spark plugs especially the front ones bugger to get too all the best. I never done a service on a bike before my TA so if I can do it sure you can.....
    Varadero Rocks
    Lutin's Avatar
    Galway
    Re: SERVICE
    Just go easy with them and you'll be okay. Not ham-fisted are you??
    Forgot to say that you'll also need to remove the headlight connector form the back of the bulb, as well as the side light connection. This last one is wrapped into the wiring loom almost, and if you didn't know, it would be easy to miss.
    You will also have to remove the windshield and the black plastic instrument surround. The little plastic fasteners, for the surround, can be fiddly but again don't go mad and you'll be okay. If you don't know, a quarter turn with a screwdriver and you should then be able to pull the fasteners straight out.
    Have fun.
    Re: SERVICE
    Do not forget to disconnect the indicators.
    Lutin's Avatar
    Galway
    Re: SERVICE
    Drat! I knew there was something that I was forgetting.
    Re: SERVICE
    I do when I remove mine and almost always wonder why the fairing does not want to come off.
    Lutin's Avatar
    Galway
    Re: SERVICE
    Quite.
    Apr 2009
    Galway, Ireland
    To Lutin
    Hiya, I'm in Galway too so we should meet somewhere round the place - on a green '01 transalp - soon to have new boxes/panniers out on! Workign in Salthill, living in Clareglaway - send us a mail if you wanna go for a spin! (tbgiw1 at gmail dot com)
  1. second service
    By paulsmc in forum Transalp
    Last Post: 07-04-09, 12:43 PM
  2. 700 alp service
    By stuart in forum Transalp
    Last Post: 01-04-09, 12:46 AM
  3. 9k service
    By stanbloke in forum Everything Orange - KTM
    Last Post: 15-08-08, 12:34 PM
  4. 12k Service.
    By mgillespie in forum Africa Twin
    Last Post: 09-02-06, 10:41 AM
