Does anybody know where the 2008 Transalp user manual can be downloaded from? Somehow this did not come with my bike.
All I need is to check service intervals, tyre pressures and the usual stuff.
Thank you
Thank you
Same problem for me too. Delivery driver forgot and then still no manual despite ringing up the dealer a couple of times who always tells me 'it's in the post.' Where did you buy yours? Not HondaDirect?
I bought mine from Malta. The Honda dealer says he is looking for a copy. If I manage to get hold of extra one I will let you know.
Can't help with the download, but my manual says the 'cold' tyre pressures should be 2.0 bar (29 psi) front and rear.
If you're carrying a passenger then the recommended rear pressure is 2.8 bar (41 psi).
Thank you for the info deskjetian. The dealer says he can order one for me.
Seems strange but anyhow
Hi Monta001
My s/h, imported from the UK TA came from a Valley Road dealer, without a Users Manual and with only one key.
For a manual, try
http://www.thesparesnetwork.co.uk/fo...opic.php?t=100
I forget if the new alp has an underseat storage box,if it does look in there,it will be in a black plastic case velcro'd to the front where it is not plainly visible,read that as invisible. that is where they hid the 01-07 one's.
