Results 1 to 9 of 9
Thread: Givi top box plate on a 700.
    Mort Guest
    Has anyone fitted a universal Givi plate directly onto the 700's carrier or do you have to buy a model specific one?
    I've looked at it but there seems to be a curve across the original carrier!
    Chad's Avatar
    wickford,essex
    Re: Givi top box plate on a 700.
    Quote Originally Posted by Mort View Post
    you found your way here then
    im not sure about the new 700 but the universal plates are usually fairly good to mount across a range of bikes.
    you could get over the curve situation by making up some spacers to raise the plate by 4-5mm
    Farky's Avatar
    May 2008
    SW Norfolk
    Ive got the model specific plate on my TA700 - sits up about 1cm at the front and levels off to just 5mm at rear as the original plate slopes a bit. The plate fixes at the 4 corners and so far has been fairly secure without squeeks, just needed tightening once worn in as such. Can imagine the uni plate working as well due to the sloe and the curve you mentioned.
    Mort Guest
    Quote Originally Posted by Chad View Post
    Thought I'd raise the tone a bit
    TopMarque is offline Member
    Feb 2008
    Berkshire
    I originally fitted the standard plate to my 700 rack, but it needed to be modified to fit. It did work OK, but, it is difficult to get the seat on and off as the rack and box protrude over the seat area. You had to bend the seat to get it off!
    Buying the 700 specific rack solved the problem.
    TM
    Aug 2008
    West Midlands
    Smile Re: Givi top box plate on a 700.
    Hello Mort,
    I have a Givi V46 topbox on my Transalp 2008 - I'm pretty sure it was supplied with a mounting plate specifically for the TA 700.
    I certainly had no problems fitting it and the seat can be removed without any problems... The nice thing is the Givi topbox can be removed very easily from the mount...
    Chad's Avatar
    wickford,essex
    yup bring some class along wi yer
    Dogman's Avatar
    Dogman is offline Member
    Jun 2007
    Northern Ireland
    As another forum member has said I have the model specific Givi adapter plate and a V46 topbox. Seat can be removed no probs and Givi is good quality.
    Mort Guest
    Thanks for your input peeps
  1. Givi Box/Plate - Fitted to Transalp
    By brownetara in forum Bodgers Corner
    Last Post: 08-05-09, 10:03 PM
  2. Help, how do I fix givi topbox plate on?
    By Jem in forum Transalp
    Last Post: 13-09-08, 11:24 AM
  3. givi adaptor plate for AT
    By Overland Ollie in forum For Sale / Wanted
    Last Post: 14-08-08, 05:31 PM
  4. Givi adaptor plate/XLV700
    By Dogman in forum Transalp
    Last Post: 13-03-08, 01:37 PM
  5. Givi Plate On Top On Honda Top Box Plate ?
    By LUNLUNZAI in forum Transalp
    Last Post: 31-07-07, 03:11 PM
