Results 1 to 10 of 14
Thread: Best quick mods to make the TA off-road capable
    Roadcat's Avatar
    Roadcat is offline Senior Member
    Apr 2006
    Cambridge
    Sometime ago I entered into The HUMM thinking that my RD03 would be back on the road with plenty of time to spare. Unfortunately unforeseen job problems arose and so money became extremely scarce resulting in me not having the neccessary cash to get new rims.
    Suddenly the HUMM is looming and I don't have a bike! So in a moment of panic, I bought a Transalp off the forums last week. It needs some work to get it running, but hopefully will pass an MOT without too much difficulty once it goes. The question is, apart from obviously putting better off-road tyres on it, what should I do (that can be done quickly and easily) to give it better off-road ability?
    Answers on the back of a post-card ...
    petterdiesel's Avatar
    petterdiesel is offline Pirate Ginger Beard
    May 2007
    Exeter
    Re: Best quick mods to make the TA off-road capable
    Hello, an aluminium sump guard and some crash bars is an idea, not sure where to get sump guards from but M & P are reasonable with crash bars.
    largewayround's Avatar
    May 2008
    Aberdeen, Bonny Scotland
    I have no idea about gearing .. But my first thought was to change either the front or rear sprockets..
    To give you more control offroad...
    Someone who knows about this will be along shortly Iam sure..
    Bolton, Lancs.
    Just put some tyres and crash bars on it
    A bit of ali under the bash plate would be good idea if you have any bits handy. Although mine has held up well, (if a little battered ).
    I find mine ok on standard gearing, . . . but smaller engine sprocket is available . . . . just take one with you and swap it when you get there if needed.
    Mine was here last week.
    Ground clearance is less than the @ but seat hieght is much less, so easy to get feet down if needed.
    FatFergie's Avatar
    Mar 2006
    I'm no expert but I've rivetted a sheet of alloy onto the plastic bellypan because it doesn't cover all the engine.
    I find the gearing too high but I suppose it depends on the terrain.
    You could consider taking off the foot rubbers to expose the toothed footrests under but again it depends on the weather and the terrain.
    Push the forks as far down the yokes as you can for ground clearnance.
    Rim lock? The older alps have the holes already in them.
    Heavy tubes for rocky stuff?
    I haven't got a clue really... I'm sure these are the things you've thought of already.
    Kjell Lindberg's Avatar
    Sweden
    If you have an early TA, you can use the sumpgard from the RD03 with a small amount of fiddling.
    pdsquire's Avatar
    Sep 2008
    Surrair
    Rather than put engine bars on, avoid damage, save money and lose weight by taking the fairings off as piguglyshandydrinker has (and I'm sure he'd LOVE to tell you how if you PM him). Depending on the model you might need to do something to protect the cooling system.
    There's not much you can do about the ground clearance save checking the yokes as above, so shedding weight is desirable both to help that problem and to allow you to manoeuvre the bike quickly to get round difficult rocks and the like.
    Have fun.
    POTSKI's Avatar
    POTSKI is offline Senior Member
    Mar 2008
    France
    I 4x4 drive/ride (a Transalp) in the Pyrenean area HUMM use quite a bit and ridden with a touch of respect the Transalp will be just fine..in fact it's my preferred bike, it never ceases to amaze me. The 15 tooth standard sprocket is what I use, no problems really. In fact off there with a mate (also on a Transalp) in a week for a few days trail riding. As others have said, a set of crash bars, and watch, reinforce or preferably replace the crap plastic bash plate...enjoy the bike and the trails.
    Potski
    btbloke's Avatar
    btbloke is offline geriatric
    Northampton
    are we talking 600 or 650?
    phil w's Avatar
    Cardiff
    Well my new old 600 alp is goin on the Humm also. From what Ive been told tourances will do but mine is gettin a new TKC on the rear.
    May get crash bars if funds allow also
  1. XR250r off-road to road conversion
    By Nogrog in forum XR
    Last Post: 06-04-08, 03:33 PM
  2. XR Mods
    By DaveS in forum XR
    Last Post: 29-02-08, 11:25 PM
  3. Air box mods
    Last Post: 09-10-07, 03:19 PM
  4. Some DIY mods....
    By lootch67 in forum Chatter
    Last Post: 14-11-05, 12:31 PM
