Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: Front end wobble
    Re: Front end wobble
    From all the threads and presumptions aired I think it may be down to the tyre compounds wearing unevenly.
    Maybe the wheels need rebalancing periodically.
    phil w's Avatar
    Cardiff
    Maybe... my front tire is best descrisbed a shhhhhite
  4. #13
    Dickster is offline Senior Member
    Jul 2005
    Kent
    Might be worth checking spokes, my rears were loose - even just after an MOT!
  5. #14
    SENSAI's Avatar
    SENSAI is offline SENSAI
    Jan 2008
    LOUTH
    check rear spokes could be loose,these leads to a front wheel wobble: and if you have a backbox take it off along with the back plate.i had the same problem and this sorted it
  6. #15
    jonnie comet is offline Junior Member
    Feb 2008
    Yorkshire
    1st post.....Should have introduced myself etc.....apologiies.......
    After owning 2 x GS's, (1150 + 1200) just bought a 700 T.A.......The very first thing that I noticed was the front end. Definitely wobbles when you take my hands off the 'bars. I will mess around with pressures, but my gut feeling is that it's the tyres.....Bridgestones, with just 1000 miles up. Again, gut feeling, new 'Tourances' at the correct pressure, should do the trick......(maybe )
  7. #16
    Jul 2005
    Kent
    yeah, i think a certain amount of "hands off" wobble is inherant.
  8. #17
    Ryan's Avatar
    Ryan is offline Member
    Apr 2008
    Spain
    Hi, lost count how many bikes i have built and owned. Had same thing with hands off and its real easy its wheel balance. Take her in get both balanced even though you only really need front and it feels like Rolls Royce after. Go cheap early! Don't play with suspension or anything like that!! Spoked wheels often do this after tyre change, clipping a curb, rough terrain or simple uneven wear on tyre.
  9. #18
    wales uk
    same happend on my fazer change the racer head bearings and got the wheel balenced it was fine after tha never had ant proplems wiht my transalp what all the bearings like
  10. #19
    SENSAI's Avatar
    Jan 2008
    LOUTH
    thanks guys.got it sorted.it was rear spokes and steering head bearing
  11. #20
    alpslapper's Avatar
    Essex
    I was just about to type +1 for having the wheel properly balanced and tyres checked. But having read your reply, I'm now changing that to check your spokes and steering head bearings.
    Your welcome
    Glad you got it sorted
  1. strange wobble/vibe front end
    By cdo1uk in forum XR
    Last Post: 07-05-09, 12:46 PM
  2. Speed wobble at 95
    By Gnasher in forum Africa Twin
    Last Post: 04-09-08, 12:03 PM
  3. Front end wobble
    By powergap in forum Varadero
    Last Post: 30-06-08, 10:59 AM
  4. Front wheel wobble/vibration at speed
    Last Post: 12-06-08, 06:19 AM
  5. Front end wobble / Anti - AT Crime wave!!
    By johntaylor in forum Africa Twin
    Last Post: 04-11-07, 10:26 PM
