Results 1 to 10 of 20
Thread: Front end wobble
    Double L's Avatar
    Double L is offline Junior Member
    Jun 2009
    Kardiff
    Talking Front end wobble
    I am a newbie here, been floating for about three years on and off.
    Had the 53 TA for nearly 3 years now (also have a GS12) and have put 18k on her 21k. Done France, Germany, Austria, Switz and Italy all in one trip and since been too Ireland, Scotland and France again.
    The reason for my post is: there has always been a wobble at the front end (when you let go of the handle bars while stretching etc) since I have owned the TA and it has never failed an MOT, its all tight upfront. The wobble doesn't bother me at all. But if I sell it, the prospective buyer may run a mile me thinks. Is there something I am missing or do I need to put a heavier oil in the front forks? or is it a trait of the TA?
    Any info would be helpful.
    Double L
    nasher123 is offline Member
    Feb 2009
    Dorset - Christchurch
    Re: Front end wobble
    i have the same thing happen on my varadero 125
    is thos just a honda fault
    what tyres are you using, have you tried the tyre pressures?
    Yeti's Avatar
    Yeti is offline Serial Scenic Router
    Jul 2004
    Darlington
    Sep 2008
    This Once Green & P Land !!
    Quote Originally Posted by Double L View Post
    Double L
    I think the problem is it comes as standard fitted with FFE - Feeble Front End !! I notice with mine if i turn the bars when its parked on the sidetand the forks feel what i can only describe as to be "flexing"
    If i do same with my GSX1400, Trident 900 or my Guzzis they all feel solid as a rock in comparison !
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Check your rear suspension settings it probably needs turning up a notch or two, have you got a top box fitted, this makes a huge difference to the front end stability, it doesn't have to have anything in it to cause a difference.
    With added weight ie Pillion and luggage you need to stiffen up the rear even more.
    Try this and check on a quiet road to see if there is a difference if your wobble stays you have to start to look deeper.
    phil w's Avatar
    Cardiff
    Still commuting on the TA then Al Keepin or changin it??
    Nice to see you on here
    Double L's Avatar
    Jun 2009
    Kardiff
    Cheers for the advice guys.
    Using tourances, the suspension at the rear has been tweaked and adjusted (not sure if you can call that screw an adjustment tho) I do have a Givi topbox fitted mind so will try it with it off.
    As I said if its normal I can live with it (well I have done 18k since I got it so have been living with it) Its just when I come to sell it on soon, I was only thinking of the new owner. I will show them this post and the thread that Yeti posted to comfort them.
    Yes Phil still commuting, and I am thinking of getting a GS1100 as my commuter as my brother now has a girlfriend and needs the extra omph up them mountain passes.
    Cheers once again
    Phil going wild camping July 18th if your free.
    phil w's Avatar
    Cardiff
    Cheers once again
    Love to but wild in the Pyrenees then
    africajim's Avatar
    Dec 2005
    Moray, Scotland
    Hi there, my @T's did the same but intermittently! By that I mean when the tyres were new and balanced the front was fine, you could let go the bars, but a few thousand miles and the front would go into a scary tremble if you let the bars go, I never found out, but I reckoned it would go into a full tank slapper if you let it?
    Worst for it I found was the Trail wing Bridgestone, my new Vara seems to be doing the same at 3000 miles!
    phil w's Avatar
    Cardiff
    Now being a re born TA rider goin down the M way today did notice bars havin a bit of a wobble, wondered if it was caused by the rubber bushy things under the handlebars, but it felt like it was running straight enough
  1. strange wobble/vibe front end
    By cdo1uk in forum XR
    Last Post: 07-05-09, 12:46 PM
  2. Speed wobble at 95
    By Gnasher in forum Africa Twin
    Last Post: 04-09-08, 12:03 PM
  3. Front end wobble
    By powergap in forum Varadero
    Last Post: 30-06-08, 10:59 AM
  4. Front wheel wobble/vibration at speed
    Last Post: 12-06-08, 06:19 AM
  5. Front end wobble / Anti - AT Crime wave!!
    By johntaylor in forum Africa Twin
    Last Post: 04-11-07, 10:26 PM
