quite right........so called " play in cable " is there in order for caliper being abled to pivot up off disc when renewing pads etc and when adjusting chain ( slide back wheel backwards and caliper moves in unison with it, hence grooved slider on caliper bracket for it to move alonggood luck
On the subject of pedal noise i have the same but found he noise could be a multitude of things since where the pedal rod connects with the brake pump clicks because of he gap. Also found that the pads rattle & stick(Yes i know they probably need changing) also the whole rear brake assembly has a few mm movement which I'm not sure it's meant to since the Front caliper is bolted on tight?
Is all that normal?
