Right I finally bought a 94 T@ recently.Its the bomb excep....t yesterday i noticed a vibration comming up through the forks into the handle bars.Just got new tyres so im presuming the front wheel bearings were checked.I did the usual tests,ie;putting her up on the centre stand and pushing the front end to see if steering head bearing is ok,no movement;
Turned the front wheel to the side and tried the wheel bearing test(pulling and pushing wheel) and it seems fine.theres loads of freedom in the steering so its not to tight but something must be loose cause when im going around bends she fights me and on a straight run if i take my hands off the handle bars they wobble from side to side.
I checked the distance from front axle to back on both sides and its more or less the same give or take a 16th of an inch!so forks are straight.
Normally id say wheel bearings.Its a conundrum!!Im bringing it back in to get them checked as its under warranty.I hoping that the guy who did the tyres missed out on checking the wheel bearings but if he checks and they're fine, is there anything im missing out on.theres no buckle in the wheel either??????!!!!
any advice greatly appreciated.....![]()
