Re: Rear brake fluid reservoir screw stuck
The screw screws into a nut which is slotted into the bottom of the reservoir casing. What happens is the screw rusts to the nut and then the nut turns with the screw mashing the reservoir plastic.
Try unbolting the reservoir from the bike and squirt some WD40 or PlusGas onto the embedded nut and then leave for a while. Overnight would be good. Once it's had a good soak, get a tiny flat blade screwdriver and try to wedge the nut to stop it turning as you turn the screw. Try giving it a slight tighten too - you just need to break the corrosion.
If that doesn't work, you'll need to get a new/used reservoir body and some new nuts and bolts. Grease the nuts and bolts before assembling it again.
