I have just returned from a short tour of Spain & France and suffered a breakdown on the first day. Whilst moving off in first gear i heard a metal on plastic scraping noise which got faster as i accelerated. I removed the front sprocket cover and then the front sprocket retainer plate and noticed that the front sprocket retainer plate inner teeth had been completely worn down, to form a smooth inner ring. This allowed the front sprocket to move freely up and down the remaining length of the drive shaft, in turn grinding against the inside of the front sprocket cover. A logistical nightmare then followed and a replacement part was sourced in Santander, which my mate went and collected. (cheers rich)
I own a 2005 TA, which i purchased with only 5000 miles on the clock and i am truly shocked that this fault has occurred.
My question's are these:
a) What can cause this amount of ware on a critical part in such a short space of time?
b) Should there be any minor lateral movement of the sprocket on the drive shaft? or should it fit perfectly with no movement at all?
Im concerned as even with the new retainer fitted, the sprocket has slight movement.
I have noticed a similar thread on the forum, which seems like the same problem. Although, i am unable to confirm whether both the front and rear sprockets on my bike are original. I would guess that when i purchased the bike with such low mileage, i would expect them to be the original ones.
Any advice much welcomed.
Lee
