I presume they dont work too well in the same tank?
Brakefluid added to the coolant tank, not on the Alp but a CB500
Graeme
Graeme
Don't run it with the fluid in there but at least with modern fluids it's not gonna damage the seals/pipe like the older fluids.
Just drain, flush with some water then refill with the usual mix
PS...when flushing do NOT use a hose pipe even if the drain plugs are out, seen too many rads go pop that way... Just use a funnel and a couple of bucketfuls of water
