Honda Trail Bike Forums
Go Back   Honda Trail Bike Forums > Honda Trail Bikes > Transalp
Reply
  #1 (permalink)
Old 27-06-09, 03:17 PM
jrob0311's Avatar
Junior Member
TA 650 Rear Suspension Preload Adjustment
I know HOW to adjust the rear suspension pre-load but have no idea by HOW MUCH!
Can anyone advise how much I need to adjust the adjuster nut to increase the preload for a pillion?
Is there a rule of thumb that people use for adjustment versus increased weight or do you just guess? I don't really want to overdo it and then have to readjust on the road.
J
  #2 (permalink)
Old 27-06-09, 03:48 PM
Frad's Avatar
IAM Member
Re: TA 650 Rear Suspension Preload Adjustment
Apparently as std the spring length should be 193-195mm, I have recently wound mine up to 185mm and the whole bike feels better, more solid in the wind and not quite as floaty as before.
Tomorrow I am trying it 2 up with luggage to try it out before our holiday in july.
I dont think I want to wind it up any more in case it becomes coil bound.
For the record Im 15 stone and the wife is less, as a gentleman never tells
__________________
XL650 '06 In Black Honda Panniers Top Box Main stand Scottoiler MRA Vario screen Givi Crash bars Oxford heated grips.
Elizabeth Kubler-Ross: Quotes: Adventure
It is only when we truly know and understand that we have a limited time on earth and that we have no way of knowing when our time is up that we will begin to live each day to the fullest, as if it were the only one we had.
  #3 (permalink)
Old 30-06-09, 09:19 AM
jrob0311's Avatar
Junior Member
Thanks Frad
Are those measurements with the bike on the ground or with no weight on the rear wheel?
J
  #4 (permalink)
Old 30-06-09, 10:04 AM
hotbulb's Avatar
Junior Member
I don't have an answer - I'm just cheekily hijacking the thread.
I don't think I need to adjust the preload just now, but would be grateful if someone could explain how to access the adjusting ring-nuts..... I can't see any way to get a C-spanner at them with the shock unit in place. Indeed, I can't see the rings at all on my V4 model.
  #5 (permalink)
Old 30-06-09, 10:13 AM
jrob0311's Avatar
Junior Member
The easiest access seems to be from the right side:
1) Remove seat and RHS panel;
2) Remove battery;
3) Remove battery box (3 bolts and unplug the electrics);
4) The top of the shock is now accessible but most people recommend using a hammer and drift or long screw driver to move the adjusting rings rather than a C-spanner - no idea if you could even get a C-spanner around the rings.
I did it the other night for the first time and it didn't take too long. Not the easiest job to do on the road I suspect!
J
  #6 (permalink)
Old 30-06-09, 12:52 PM
Alba's Avatar
Senior Member
Quote:
Has it made any difference to the handling as noticed by Frad
__________________
'52 TA Honda top box, HID conversion, 47T rear sprocket, K&N air filter, Tourances rubber
  #7 (permalink)
Old 30-06-09, 01:07 PM
hotbulb's Avatar
Junior Member
Thank, j, for the explanation of access to the adjuster. When I first had the bike I thought it might be useful to adjust the preload to lower the bike a fraction (short legs!), but I've got used to it now.
  #8 (permalink)
Old 30-06-09, 04:48 PM
Frad's Avatar
IAM Member
Thanks Frad
J
On the centre stand, so no weight on the rear wheel
__________________
Reply
Tags
650, adjustment, preload, rear, suspension, ta
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
New XR400 Owner - rear preload kiwijohn XR 2 15-05-09 02:13 PM
rear suspension adjustment, Help! Yahoo Transalp 10 14-02-09 03:46 PM
Rear suspension adjustment XLV650V ADTT Transalp 11 07-07-08 06:08 AM
rear suspension adjustment Whealie Africa Twin 3 23-05-07 06:23 PM
Rear suspension adjustment ddcristi Africa Twin 2 02-09-05 05:28 AM
