Re: Side-stand spring.
I took my spring off a month or so back and it was brute force and ignorance
I have a 52 plate, can't be much different. If I remember correctly the bottom loop of the spring needs pulling down then moved towards the centre of the bike, as it is in a recess. Then the top spring loop should be removed from a hole. Pair of pliers and a skint knuckle should do it
I done it with the stand down due to access.
I hope this helps.
Varadero Rocks
