Results 1 to 7 of 7
Thread: Suicidal Brake pads
    Grendel's Avatar
    Southampton, Hampshire
    Suicidal Brake pads
    OK as a few of you know i recently changed my rear pads and pad pin and so far coverd over 100miles with no fault untill today?
    After riding home with no fault as i pulled up in garage one just fell out broken ?
    My TA 600 Page:
    Southampton Safe house
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    Re: Suicidal Brake pads
    EBC by any chance??
    Merv
    Grendel's Avatar
    My TA 600 Page:
    Grendel's Avatar
    No standard ones from Wemoto but asked for EBC as replacements.
    The chap at Wemoto said it looks like i didn't fit them correctly so they came out but i have covered over 100 Miles since fitting them with no problems so if i fitted them wrong surely they would of fallen out a lot sooner?
    My TA 600 Page:
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    hi grendel ,
    the same thing happened to me a while back , yes ebc pads from web moto[not their fault] I should have listined to higher advise
    Buy some genuine from david silvers tehy are awsome and have the backing shime and are sintered as std, go on you know your life depends on them and they aint much dearer
    tramp
    MandoBear's Avatar
    Herefordshire, England
    How come the backing plate on the left hand one is bent at the "loop" where the pin should go through?
    Grendel's Avatar
    Quote Originally Posted by MandoBear View Post
    That happened when it somehow got pulled out of the caliper? I could understand them failing if not fitted properly but i have had over 100 miles worth of use out of them with no problems so cant think why they would decide to brake now with no reason?
    Hopfully they will be sending me EBC Organic pads to replace these.
    My TA 600 Page:
  1. Brake pads - which are the ones to go for?
    By LUNLUNZAI in forum Varadero
    Last Post: 18-08-08, 12:30 PM
  2. Brake pads... what.. how much!
    By tee pee in forum Transalp
    Last Post: 22-11-07, 11:44 PM
  3. Brake Pads
    By sting-stiz in forum Africa Twin
    Last Post: 26-05-07, 05:50 PM
  4. brake pads
    By 5135jimmy in forum Africa Twin
    Last Post: 10-01-07, 10:06 PM
  5. Brake Pads
    By pooh in forum Africa Twin
    Last Post: 18-09-06, 05:59 PM
