Re: Running very hot?????
Originally Posted by
chalky4
water level just above the internal fins and overflow bottle between low and max
The water level should be up to the filler neck i.e. with no air in it. If there is air in there, it's a sign that either it can't pull coolant back from the reservoir when it cools due to a faulty cap, or it wasn't filled properly. If the cap is faulty it won't pressurise properly.
It is also quite possible that the water pump impeller has rusted away if it's an older bike. Was the water very rusty when you drained it and was there antifreeze in it?
