Results 1 to 4 of 4
Thread: Barkbusters and Vario Screen TA700
    Twickers's Avatar
    Twickers is offline Senior Member
    Jan 2009
    Twickenham, TW2
    Has anyone else fitted both a set of Barkbusters and a Vario Screen to their TA700 ? Fitted the Vario screen at the weekend for a long ride up to Yorkshire . No problems , but I've noticed that on full lock part of the deflector on my Barkbusters is slightly touching the edge of the screen, and I'm worried that in due course (albeit a couple of years down the line ) this might be considered an MOT failure.
    Anyone else had this problem or is it just me? Any ideas? An extra spacer piece behind the Vario screen perhaps (it is supplied with little rubber spacers already) ?
    Transalp 700, heated grips, SW Motech crash bars, Barkbusters, centre stand, short@rse seat, Vario screen, Givi E21s, CR85 folding gear lever, Trax top box.
    The beatings will continue until morale improves...
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    Re: Barkbusters and Vario Screen TA700
    hi twickers,
    I ahve a 650 transalp with high touring screen and std honda hand guards fitted , last mot at a triumph dealer he said my guards touched the screen edge on full lock. So I said everything is std honda fittment and as it was touching the stops on the top yoke whats the problem, nothing he said just be aware it might fail elsewhere.
    had it tested elswhere this year and no probs even when I enquired about this je said dont worry they all do that and anyway no one goes on full lock when driving.
    The only time it caused a problem was when picking up dropped bike but have since moved bar ebd out 5mm so it dosent touch anymore with no probs noticed.
    tramp
    jasonbc's Avatar
    Camborne, Cornwall
    CAn't you just Swap the screens backs for the MOT if your worried about it. Cant see it being an mot failure
    GASGAS TXT250 PRO 2006
    btbloke's Avatar
    btbloke is offline geriatric
    Northampton
    adjust the bars back a bit have mot then back-adjust
  1. Who has used a Vario Screen
    By rick001 in forum Transalp
    Last Post: 09-07-08, 09:45 AM
  2. MRA Vario screen TA
    By tonythesaint in forum Transalp
    Last Post: 18-05-07, 09:04 AM
  3. Replies: 7
    Last Post: 28-06-06, 09:33 PM
  4. MRA Vario screen.
    By miggy in forum Africa Twin
    Last Post: 05-01-06, 02:11 AM
