Results 1 to 3 of 3
Thread: TA 650 restrictor dimensions?
    jarl's Avatar
    jarl is offline Senior Member
    Apr 2009
    Bath
    Sorry to do this, but my internet at home is down so I'm currently at a library which have given me 20 minutes net time which I'm halfway through and haven't found an answer, so I don't suppose anyone can tell me the dimensions of a TA 650 restrictor washer? I've heard that on the 650 it's actually replacement rubbers, which may be an issue. I'm wanting to do a bodge job of restriction (i.e, avoid paying £150 for the kit) but it's tricky to decide whether this is doable without knowing the dimensions or specs of the restrictor kit.
    Cheers!
    hotbulb's Avatar
    May 2009
    Cardiff
    Re: TA 650 restrictor dimensions?
    I'm sure someone will have the actual dimensions you need.... but surely you need the certificate confirming the machine's restricted.. and it's this that costs!
    btbloke's Avatar
    btbloke is offline geriatric
    Northampton
    The restrictor is built into the moulding of the carb to head rubbers,i think someone on here has an old set put a wanted thread up and you should get a response
  1. Help needed: Dimensions of @'s OE handlebars
    By LUNLUNZAI in forum Africa Twin
    Last Post: 03-11-08, 06:34 PM
  2. SPRING dimensions
    By z-weiser in forum Varadero
    Last Post: 24-10-07, 09:49 AM
  3. Hub Dimensions for new wheel?
    By BuckarooBanzai in forum Transalp
    Last Post: 29-07-07, 08:49 PM
  4. Top Box dimensions--PLEASE!!!
    By Xander in forum Mechanical Advice
    Last Post: 14-11-06, 10:55 AM
  5. Restrictor Kit
    By AT Kid in forum Africa Twin
    Last Post: 28-05-06, 11:04 PM
