Results 1 to 6 of 6
Thread: increased handel bar vibrations.
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    hi all,
    my 650 v2 transalp has developed a very annoying handlebar vibration . leaves the right hand with pins and needles after only 30 mls ride at about 4-5000 rpm, never did it before.
    The only thing I`ve done recently is adjust the stearing head bearing as requested at the mot, stearing fine no tight spots etc.
    Any idead what to do or check bike only done 24,000mls and usually runs sweet and smooth,
    tramp
    Sep 2008
    This Once Green & P Land !!
    Re: increased handel bar vibrations.
    Any chance a Handlebar weight has come "free" & is hammerin around inside the bar ? (i think they are fitted inside )
    Have you damaged yr Right Wrist ? (Naughty Boy )
    Apart from poss loose weight cant think of anyhting else myself
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    hi silalp,
    no nothing loose, just removed bars and checked they are seated properly and retorqued nuts, will have a ride tomorrow to see if any better.
    maybe I dislodge something fitting the satnav a while back and running the feed cables etc.
    ps I a ambidextrace so 99 and change hands
    tramp
    Treadtrader's Avatar
    Treadtrader is offline White van man
    Jul 2007
    Warwickshire
    It could be the carbs have gone out of sync and the engine needs a tune-up. This can produce a vibration.
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    hi all,
    thought i`d do a update, seemed to have solved the problem what ever it was by removing the bars and reseating and retourque the bolts.
    before winter come will replace the cheap and usless heated grips with oxford ones so that should rule out cheap grips . ps bar ends okay and thaks for the search tips,
    tramp
    Austin's Avatar
    GARSTANG
    I get this when my carbs need sync'ing. or when i have a death grip on the bars - conscious relaxation is needed sometimes.
  1. Vibrations??
    By Scooter in forum Africa Twin
    Last Post: 25-06-09, 02:53 PM
  2. Vibrations
    By Wigan Chris in forum Africa Twin
    Last Post: 29-09-08, 04:30 PM
  3. Vibrations
    By transalper in forum Transalp
    Last Post: 31-03-08, 08:57 PM
  4. Replies: 1
    Last Post: 10-02-06, 09:17 PM
  5. African Queens increased ride height kit
    By wheeliebin in forum Africa Twin
    Last Post: 19-12-05, 09:59 PM
