Results 1 to 10 of 13
Thread: valve clearance on honda xl700 transalp
    johndev is offline Junior Member
    Jul 2009
    ireland
    Does anybody know the specifications for the valve clearances on both cyclinders on the Honda XL700 Transalp ????.
    Appreciate that info.
    sadpsych's Avatar
    sadpsych is offline The psych with the bike
    Aug 2008
    Notts
    Re: valve clearance on honda xl700 transalp
    From good old Mr Honda's book of filth (ie. workshop manual)
    Engine MUST be cold (Below 35 C)
    IN: 0.15 +/- 0.02mm (0.006 +/- 0.001 in)
    EX: 0.20 +/- 0.02mm (0.008 +/- 0.001 in)
    Lock Nut Torque = 10Nm (7 lbs.ft)
    Hope that Helps
    Gold 700 TA, Touring screen,Heated grips, Givi Panniers & Top box, Centre Stand, Bar Risers Fenda Extenda and Scott Oiler. So Far (still hoping for some Crash Bars)......... Oh and nearly forgot, A wife with a Hog , Back in the saddle after some spinal carpentry and looking forward to making up for the lost 18 months
    Quote Originally Posted by sadpsych View Post
    Hope that Helps
    That is why I did mine in the winter, Can't get much colder.
    Jul 2009
    ireland
    Thanks sadpsych....
    appreciate that help with the valve clearance spec.
    What type of book have you got ????.
    What do you make of -8 degrees celcius...??
    sadpsych's Avatar
    Aug 2008
    Notts
    I've got the Honda Workshop manual, IMO Better than a Haynes. Costs about £25 From Mr honda. Theres another thread on here that gives the Part Number.
    As for the Temp, Should be Cold eough for setting the clearances but how you going toget the alp in the freezer???
    Jul 2009
    ireland
    Re: intake and exhaust valves
    Thanks all for info on shop manual...got it from Bridge Honda couple of weeks ago.
    BIG QUERIES HERE.....
    How exactly do you identify the intake from the exhaust valve ???. Are they placed in certain parts of the cylinder ???. Are the intake valves on the front of the cylinder ??? and the exhaust valves on the back of the cylinder ???.
    I also noticed in the book that they use a torque wrench that seems to fit into all sorts of tools like spoke tightener and assuming the 4 mm tappet wrench required for the adjusting screw on the valve.
    Is it very important to get these tools or will a spanner and pliers do.
    I am seriously wondering how to tighten the lock nuts to the specified torque if a traditional torque wrench (the ratchet head type) doesnt fit in there.
    Finally, the fuel needs to be disconnected before the throttle body is removed for the valve clearance to go ahead.......will the HONDA shop readily sell items needed to replace the quick connect system (the plastic retainer) ????.
    Appreciate all assistance.
    Oh and finally, does anyone know where I can get my hands on all the parts numbers for the components of the Transalp XL 700 V so that I can order them more easily......some person has the product codes for the XL 700 VA9 on this site.
    John
    Quote Originally Posted by johndev View Post
    When you veiw the head there are to covers one by the exhaust is for the exhaust valve, the one near the throttle bodies is for the inlet.
    They can be adjusted with pliers and spanner.
    They can be done up by hand just nip them up do not apply too much pressure.
    John
    Some of the fuel pipe parts must be changed every couple of years so the parts can be purchased, if they are in stock.
    As for the parts numbers I can not help you.
    deskjetian's Avatar
    deskjetian is offline Senior Member
    Apr 2009
    The Midlands
    John
    Look here.... Honda Transalp 700 Forum - www.Transalp700.org • View topic - Honda XL700VA9 Parts Catalogue
    Jul 2009
    ireland
    Re: two covers on cylinder head
    Hey sadpsych !!<
    thanks for the information about the inlet and exhaust valve location.....I am a germinating motorcycle enthusiast....need more info on that exact description.
    So if I look at the engine from the right side of the bike there are two cylinder heads...I hope.
    Okay, are all of the exhaust valves under the cylinder head at the back near the exhaust ???. I assume the four valves are to be checked against the exhaust valve specs ???.
    Are the inlet valves under the front cylinder head cover ???.
    I assume that there are also four inlet valves under that cover ???. And I assume all four valves under the front cylinder head cover are to be checked against the inlet valves spec ????
    Can you explain to me in a little more detail since I dont know exactly ???
    I will appreciate your help there.
    John
    If you look at the top of the engine you will see two heads, one for the front cylinder and one for the back each has two exhaust and two inlets.
  1. SLR valve clearance
    By Daz Max in forum Dominator / FMX
    Last Post: 25-05-09, 10:19 PM
  2. Valve Clearance XL650 2005
    By boomer84 in forum Transalp
    Last Post: 03-03-09, 01:26 PM
  3. TA650 recommendend valve clearance
    By transalper in forum Transalp
    Last Post: 24-05-08, 01:49 PM
  4. Quick question about valve clearance
    By darthDassie in forum Africa Twin
    Last Post: 28-11-06, 09:46 AM
  5. VALVE CLEARANCE
    Last Post: 26-04-06, 08:38 PM
