Ok... following rebuild its all going back together really well and started first time !
However.... the neutral light stays on when I engage a gear ... any ideas anyone ?
thanks
fro5tie
thanks
fro5tie
Hmmm...
Did you go into the gearbox during your rebuild?
Hi
check your lead to the neutral switch. They sometimes get pinched and earth!
Hi
- didnt go into the gearbox
- Ryan... which one is the neutral lead ?
cheers
fro5tie
I'm not sure what bike you have but on my '94 600 the neutral switch wire is red/green coming out of the engine with the oil pressure switch lead. It does sound as if you've shorted it somewhere.
Hi Fro5tie:
i've got exactly the same problem (on my Transalp XL600V 1999) which started a couple of days ago - did you get it sorted, and if so could you let me know what it was in the end?
All the best,
Joops.
