Results 1 to 9 of 9
Thread: Oil FIlter
    Apr 2009
    Galway, Ireland
    Oil FIlter
    Hiya, i got a replacement oil filter for my 2001 transalp - only it seems shorter (stubbier) than the one thats on the bike - seems to be the same diametre though. Will this be a problem or is it just different filters are different sizes, as long as the screw in bit fits? Thanks, TB
    PS - got the replacement one from David Silvers so i'm assuming they sent the right one!
    FatFergie's Avatar
    Mar 2006
    Re: Oil FIlter
    If it looks like this:
    then it's the right one and it'll be fine. I don't know anything about different sizes or whether it matters. I've used different makes and they seem to be the same size.
    Austin's Avatar
    GARSTANG
    Re: Oil FIlter
    I have had long one's and short one's. I just fitted them and watched for the Oil Pressure light to go out (and stay out). Been OK, I seem to always get the short one's now - which are easier to fit as they clear the frame easier with the removal tool on.
    Apr 2009
    Galway, Ireland
    Re: Oil FIlter
    Thanks Guys, will check the serial number later when i get home. And fingers crossed do the job tomorrow evening!
    Re: Oil FIlter
    I have ordered the Tree pack from David Silvers and the part number on the filters is 15010 - MCE - H51 They are the short ones but look to fit the bike easier, more access space.
    Apr 2009
    Galway, Ireland
    Re: Oil FIlter
    Feel a bit better now, always better to ask than not, i reckon!
    btbloke's Avatar
    btbloke is offline geriatric
    Northampton
    Re: Oil FIlter
    The one you have tara is the old one,no different from the new one,the part number you have has been superceded by the part number stumpy has posted,nothing to worry about just old stock being sent out. david silvers buys up old stock from all over the world,he'll buy from dealers who close etc so he's just bought a load of old filters and is sending them instead of the newer ones,it's no big deal they don't go off.
    default Guest
    Re: Oil FIlter
    The last ones Got from DS were rusty inside, so maybe very old stock, not much of a discount either.
    btbloke's Avatar
    Northampton
    Re: Oil FIlter
    I would have sent that back steve, personally i use hiflo or champion,i find they work as well if not better as the rubber seal seems to be more substansive on the champion and the hiflo have never given me any worries.
  1. K&N Filter oil sp-ray ok for No Toil Filter
    By Kermit in forum Mechanical Advice
    Last Post: 07-10-08, 02:12 PM
  2. New Plug, Oil + Filter & K&N Air Filter
    Last Post: 10-01-07, 05:50 PM
  3. oil for the air filter
    Last Post: 11-07-06, 04:44 PM
  4. Oil Filter
    Last Post: 06-01-06, 11:29 AM
  5. K&N Filter
    By Gregger in forum Africa Twin
    Last Post: 29-11-05, 06:24 AM
