Results 1 to 6 of 6
Thread: K&N Air filter
    Titch's Avatar
    Titch is offline Senior Member
    Feb 2009
    Oldham, Manchester
    K&N Air filter
    Hi guys 'n' gals,
    If I'm gong to fit a K&N air filter to my TA what else do I need to change ?
    Titch
    Re: K&N Air filter
    I put a piper cross filter on mine with no changes, it removed the flat spot but did nothing else.
    SENSAI's Avatar
    SENSAI is offline SENSAI
    Jan 2008
    LOUTH
    Thumbs up Re: K&N Air filter
    you may need to re jet it.do you have an after market can on it
    Austin's Avatar
    GARSTANG
    Re: K&N Air filter
    I put a K&N on mine at 8,000 miles and its been on there for the next 60,000miles. No problems. I have also removed the catalyst, rejetted (smaller 125 jets) and run a GP (brand) silencer. Each of which should make make the bike run leaner, but it runs fine and plugs come out looking like there is a good mixture. On my experience then you probably don't need to do anything as TAs are notorious for running on the rich side, but you should judge for it yourself and if in doubt get it checked at a dyno or a bike shop.
    Grendel's Avatar
    Southampton, Hampshire
    Re: K&N Air filter
    Have a K&N and Arrow dakar can on my 600 and havent change a thing. But does make it run a bit smoother.
    My TA 600 Page:
    Southampton Safe house
    Mar 2007
    Bridport Dorset
    Re: K&N Air filter
    this is a usful thread to find this rainy day as i was going to ask the same question myself.
    so cheers all will go order one when the rain stops!
  1. K&N Filter oil sp-ray ok for No Toil Filter
    By Kermit in forum Mechanical Advice
    Last Post: 07-10-08, 02:12 PM
  2. new oil filter??
    By GeoBloke in forum Africa Twin
    Last Post: 13-08-07, 03:44 AM
  3. K&N Air Filter?
    By ttaattaa in forum Transalp
    Last Post: 31-07-07, 09:58 AM
  4. New Plug, Oil + Filter & K&N Air Filter
    Last Post: 10-01-07, 05:50 PM
  5. AT air filter
    Last Post: 19-08-06, 06:20 PM
