Results 11 to 20 of 24
Thread: TA 700 '09 original Honda top box?
    Adam's Avatar
    Adam is offline Wookie in leather
    May 2009
    Birmingham
    Re: TA 700 '09 original Honda top box?
    Can I just point out here that the 'Honda' top box is made by Givi. It is just branded as Honda...
    vdv2020's Avatar
    vdv2020 is offline Junior Member
    Aug 2009
    Luxembourg
    Lightbulb Re: TA 700 '09 original Honda top box?
    Hello,
    I will have some pics for anyone who needs to see it. For now I can say:
    1. The base is damped horizontally (left-right). It's no hydropneumatic suspension but it's there. Damping on mine is quite soft.
    2. The alu look is like metal. Or is it actual metal. Deeper investigation pending
    3. The handle part takes a bit of space from the inside. Shame, but it has a handle.
    4. By default there are only simple stretchy straps to hold (large) contents. No lining, just bare hard plastic.
    5. Hinges look OK.
    6. One key to open, one key to remove, one key to rule... Works OK.
    7. The box is blocking removal of the seat! I have to remove the box first to be able to remove the seat. Not good. It's a close call, so maybe a solution can be found.
    8. Removal/installation on base very easy.
    Any questions?
    Cheers,
    VdV
  4. #13
    Transalp Tim is offline Member
    UK
    I have the Honda top box and panniers, colour matched (gold) to the bike.
    Top box is expensive but so far has proven invaluable: room for 2 helmets, and can carry laptop, clothes, lunch, etc., to work. It's on the bike almost all the time whereas panniers only go on when needed (easier to filter).
    My pillions have also complained that it pushes them further forward and makes the ride less comfortable and so I have considered making a new mounting plate to move it a couple of inches further back. Still to have a go though.
    Re. the other negatives previously mentioned in this thread:
    • Key scratching the bars when the main key is in the ignition - I rest the top box key in between the brake hose and throttle cable, which avoids any rattling or scratching.
    • Float/damping - this has never been a problem for me; no rattling or any sense that something is loose.
    Panniers are well made but smaller than they first appear, particularly the RH one, where Honda have been over generous with the exhaust clearance. Fitting the mounting frame was a PITA! The weld nuts on the RHS (where the stay bolts near to the engine) were soft and I couldn't tighten the bolts to the correct torque; I resorted to putting a nut on the end of the bolt behind the weld nut but could physically only get a spanner around one! So far they've survived 8000 miles, so fingers crossed for the years to come.
  5. #14
    Soottie Chief's Avatar
    Soottie Chief is offline Junior Member
    Oct 2009
    Norwich
    Hi all
    I was lucky enough to get my Honda Top Box free as part of the winter package when I bought the bike. So nothing to compare it with, but it works fine, looks good, I can get the proverbial kitchen sink in it, and it almost never comes off the bike.
    TRhe only thing I will say is there is a lable inside which states to keep the speed below 80mph when fitted. Not sure why, but I use it to keep me sensible.
  6. #15
    btbloke's Avatar
    btbloke is offline geriatric
    Northampton
    Quote Originally Posted by vdv2020 View Post
    Hi,
    Does anyone have the original Honda Transalp top box (colour or alu)? In your opinion - is it worth the money (~300-350€)? I can't find a decent review of it. How does it compare to GIVI or other similar?
    Any info appreciated. Thanks.
    VdV
    Genuine honda top box for transalp 700 on eBay (end time 08-Oct-09 18:07:49 BST)
  7. #16
    Bluff's Avatar
    Bluff is offline ???
    Aug 2009
    Just over there
    Quote Originally Posted by Soottie Chief View Post
    Hi all
    TRhe only thing I will say is there is a lable inside which states to keep the speed below 80mph when fitted.Not but its a cute puppy Not sure why, but I use it to keep me sensible.
    evening nancy
  8. #17
    sporlan66's Avatar
    sporlan66 is offline Senior Member
    Aug 2008
    canterbury
    I have the Honda top box,which has excellent capacity,i have found the handling affected on windier days,so as such avoid using it,the problem i have had is the blanks that cover the mounting bolts have jumped out,four out of six so far.None seemed particularly loose,but they still disappeared,not as though you can glue them in either.Got to source some new ones as plate looks crap without them.
  9. #18
    vdv2020's Avatar
    Aug 2009
    Luxembourg
    Inside of the box as it came from the shop:
  10. #19
    Where is the mat?
    Mine has a mat which hides the bottom.
  11. #20
    vdv2020's Avatar
    Aug 2009
    Luxembourg
    There was no mat Everyone had the mat in the box by default?
  1. the 'original' orange
    By boboneleg in forum Everything Orange - KTM
    Last Post: 03-05-09, 02:49 PM
  2. Not an original thought,
    By stageonesimmo in forum Bodgers Corner
    Last Post: 02-09-08, 09:16 AM
  3. MOT without the original baffle
    By Beeaj in forum XR
    Last Post: 28-02-08, 11:23 PM
  4. Original Exhaust
    By pooh in forum Africa Twin
    Last Post: 29-08-06, 09:43 PM
  5. Has anyone met the original owner ....
    By fw750x in forum Chatter
    Last Post: 18-06-06, 10:05 PM
