Re: Fork oil swap.
Originally Posted by
FatFergie
My 600 doesn't have them but to be frank it makes it easier to get all the old oil out and reset the level (and clean out the gaitors) if you take them off. Be wary of draining the oil out the damper bolt holes; if you loosen the bolts it can be a pain to get them tight again as the damper can spin round inside the fork.
My tips for oil changes?
- Loosen the fork caps before loosening the yoke clamps.
- Flush the old oil with a little fork oil.
- Drain them upsidedown overnight.
- Leave the damping and seals alone unless there's a reason for it.
I use 5 wt oil but I'm on a 600. Not sure what yuo need or how much.
Good points, thank you, especially the overnight tip and leaving the seals alone. Do you change the o-ring in the fork cap, assuming there is one?
I was picking up a battery for family scooter today and asked the local dealer for a price and was quoted about £110, forks on the bike! As I said to the lass, if I got the forks off, I'd do it myself!
A task for the winter when the bike is effectively off the road I reckon.
I have now located the pdf of the service manual on my PC! And it does indeed go through the procedure of removng the fork legs to change the oil.
steveR
Project Red KMX200
