Re: 650 TA handling
Not sure about dropping the forks, but you do know that you can adjust the preload on the rear shock, don't you?
Yes it is a fiddle, as to get reasonable access you have to remove the right hand side panel, battery and battery tray. But if you are intending to load the bike up and leave it that way for some time, then it is probably worth doing.
