Results 1 to 2 of 2
Thread: Touratech - lights swap 650 to 700
    Merlin_Morris is offline Junior Member
    Apr 2007
    Lincoln
    Hello fellow Alpers
    I've had a 650 for a few years and just swapping for a 700 . I've Touratech spot & fog bolted on the top of the inner fairing above the Touratech crash bars . yes my night vision is S**te.
    Does anyone know if I can fit these to my 700 without much modification work .. or is it a call to Touratech for new brackets ?
    Re: Touratech - lights swap 650 to 700
    Depending on where you want them exactly, you should be able to mount them with a little effort on your new fairing in the same way.
  1. Fork oil swap.
    By steveR in forum Transalp
    Last Post: 22-05-10, 07:03 PM
  2. council swap
    By fionaann in forum Chatter
    Last Post: 15-11-08, 02:30 AM
  3. Honda Swap
    By dazzerrtw in forum For Sale / Wanted
    Last Post: 05-05-08, 08:03 PM
  4. swap my MX5 For a XR400 Or 650
    By dazzerrtw in forum XR
    Last Post: 18-11-07, 04:32 PM
  5. Do I swap
    By fawcettpark in forum Transalp
    Last Post: 26-11-05, 07:32 PM
