Whilst giving the TA a look over before a ride-out I spotted the throttle bracket digging into a coolant hose (see pick). It had worn quite a bit into the hose. Bodged it with a thick inner tube patch and duck tape. Waranty claim I think? Can I ask you, when your TA is cold can you see any colant at all in the expansion tank when on side stand ? Mine seems empty. Ride safe Dave.
i thinks its only the oil you check when warmed up. ive always checked water levels when cold ( overnight ) and make sure its between min / max. dont think its ever dropped to min..........never mind `empty` dont forget when running the water / oil systems are pressurised ( hence the hiss when opening cap ) good luck with it..........and watch your hands !!!
