Gents
Finally returned to the TA fold after an enforced absence of nearly a year. This time, I am bestride an 08 700 TA, replacing the aged 600 I had last time. Between jolly jaunts offshore, I have managed to ride it a few times and for what it’s worth herewith my opinion so far…
Engine sounds and pulls well. Fuel injection is very responsive, and having always had carburettors, something I have still to get used to. I find it particularly sensitive, especially feathering the throttle round corners and blipping when changing down. Goes well on accelerating, and seems to have much more oomph lower down. Very useful for overtaking with minimal foresight. Fuel economy no idea as yet, but the ever pessimistic fuel gauge remains. Why is it not possible to make an accurate fuel gauge? The digital readout and the MFI nonsense is OTT for me, but then I favour analogue controls – much quicker and easier to read and understand where you are in the range measured. Clock is a welcome addition though.
Riding position seems very comfortable for me. Custom screen and bar risers have been fitted which seem to work well. The rider bum rest on the seat is a little too far back, but otherwise riding position is pretty much as before. Wind buffeting is minimal, but then a slightly higher than standard screen is fitted, and for me, the bar risers are an improvement. I now have the luxury of twin discs and ABS! Not sure if ABS isn’t just a gimmick and something else to go wrong – the jury’s out on that. Got to be better than a puny single disc I suppose. Box and clutch are the usual Honda light touch. I moved the gearlever round a notch or two on the spline to suit, and it made a welcome improvement to shifting smoothly. It seems supremely stable round the bends and holds the line very well indeed – on Battleax’s. The old TA was good at this too, but this one is better - 19 inch wheel? Larger rear? Personally this is something I like in a bike. Any fool can go fast in a straight line, but it’s cornering which sorts the men from the boys, and the responsive FI assists in pulling you out of the corner very smoothly - though I still have to decide whether to adopt the knees in fairly upright position or knees out, crouched slightly forward position when leaning into the corner. The former seems hairy on a tall bike, but both seem to work. It takes off pretty well too, even at around 70 mph in top. For the mountain roads up here in Aberdeenshire it seems very well suited. I have not tried the motorway as yet - cruising anyone?
Fit and finish is generally pretty good. I don’t particularly mind the plastic stuff. For me, it looks well enough and assists in giving a little more wind protection. Yes some of the fasteners are naff, but then they are on most other bikes. I’ll end up replacing dodgy ones with stainless anyways. Push lock fuel cap, handlebar lever adjusters, the odd bit of chrome are quite nice touches however. I am currently re-spraying the exhaust tail pipe. Here the paint is way too flaky, so a coat of HT semi matt black to match the side panels/front mudguard should improve matters a little. Engine finish seems good, and the simple black and blue paint scheme works well – not sure about the transfers and all the GPS rubbish, but then I can read a map. Of course, just like the last TA, the rear spokes are starting to dull. I’m never sure what to do here – polish it up with wire wool? I did this on a few with only a minor improvement. Will this remove any protective lacquer? – and even if it did, then so what. Lacquer can’t be much good; otherwise spokes wouldn’t dull in the first place. Front is fine. Just hope the rims don’t go the same way as the crappy anodised gold finish on the old TA. Problems anyone?
Improvements – when I purchased, it came with the bar risers, engine bars, matching top box, bigger foot on side-stand, soft panniers, scott-oiler and heated grips – yes, yes big girl’s blouse, but then I’m in Aberdeen – further North than Moscow. I’m thinking about a centre stand – just for chain adjustments and such like, but I also have a paddock stand, which negates it somewhat. It also came with a metal arrangement of about 10mm diameter which protects the soft panniers from the exhaust and stops them rubbing on the rear panels. With a bit of bracing, they may take hard panniers. Any further useful improvements done by anyone?
All in all an enhancement over the old TA in many areas, and definitely more of a road bike - to be fair, it was ever so. Personally I prefer the higher riding position, the fact that it is not an in-line 4, the slightly aggressive stance, the smooth drive-train and the proven reliability. The fact that I went to Switzerland and back on the last one with no trouble at all bodes well for this one – now where is my Michelin map….
