Results 1 to 3 of 3
Thread: Coolant recommendations
    shack's Avatar
    Jun 2007
    Devon knows why I'm so creamy
    The coolant debate is warming up, but the thread is getting long and winding.
    Might it be worth compiling a small list of coolant brands readily available, their cost and location to buy.
    Tis sure the time time to be checking and changing.
    Re: Coolant recommendations
    I have no idea which coolant brand I use, I get mine from work.
    davedixon Guest
    You need a high quality ethylene glycol antifreeze with corrosion inhibitors specificaly recommended for aluminium engines which does not contain silicates. These may cause wear of the water pump seals or blockage of radiator passages. Use with distilled water. See your owners handbook. Dave.
  1. coolant
    By yoashman in forum Africa Twin
    Last Post: 21-07-09, 12:44 PM
  2. Coolant leak
    By fro5tie in forum Transalp
    Last Post: 14-07-09, 08:53 PM
  3. Using coolant.
    By MR.T in forum Transalp
    Last Post: 25-04-08, 01:53 PM
  4. Coolant Help!!
    Last Post: 23-03-06, 08:47 PM
  5. coolant??
    By saintvice in forum Africa Twin
    Last Post: 05-12-05, 05:43 PM
