I changed the pads today.
The bike has 12,000 miles and I was doing intermediate service myself.
I bought the pads for my old DV700 but traded it in before I got round to fitting them. They are the same for TA so I keft them.
2 bolts each side to remove housing, I suggest loosening the holding pin first.
I am sure that the pads could be replaced without removing housing but it is so easy and you get the opportunity to clean inside.
NB you do not loosen hoses etc
The pads are handed
i.e. one pair for n/s disk and another for the o/s disk.
I suspect the differences are in the shim position.
With me, the shim was put on the back of the slave pad, i.e. not the one pushed by the pistons.
It may be best to do one side first then the other, then you will not have 4 pads to consider
when the new ones are slotted in, use a flas screwdriver or similar to maximise the gap between the pads.
slide gap over disk and re-bolt to frok
NB
remember to pump BACK brake pedal as well as front brake to bring pistons and pads up to disk.
the middle piston is operated by the rear pedal.
I think it is only on one side.
Total job time about 15 mins
takes longer to clean hands.
hope this is of interest to anyone who has never renewed pads (yet).
I forgot to mention, put a bit of copper grease on the back of the pad pushed by the pistons and on the barrel ofthe holding pin.
This reduces squealing when brakes applied.
SMcG in Glasgow
