Results 1 to 5 of 5
Thread: No choke required
    mostlyskint Guest
    No choke required
    Hi All
    Ive had my 99 xl600v for a year now, commuting every day. Can't fault it, top bike.
    Strange thing is I've never used the choke from the day I got it.
    On servicing, the plugs are the right colour and its doing 55mpg.
    I just wondered if the rest of you 600 owners have the same experience?
    If i try to use the choke or open the throttle during starting she wont go, just push the button and leave well alone and she starts first time every time.
    Any ideas
    thanks Dave
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    RidingAlongOnACarousel
    Re: No choke required
    Ditto the above - top bike the 600 TA
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    hi ,
    thinh the carb set up is same as 650v then the choke plungers are a real pain in the ass,
    Always requiring pulling out and spraying with wd40/acf stuff, usually every 6mnths more if it rains a lot.
    think the rain runs down cable from choke set on bars then corodes the springs, a good spray of the spray does the stuff.
    But normally you get eratic tickover when engine hot and at least wrong plug colour, sounds to me the jets were changed as when choke applied -ie fuel richer it wont start so mixture wrong or air filter blocked.
    happy fiddling
    give the bike a good spray with "acf" now and forget about cleaning till spring.
    tramp
    Austin's Avatar
    GARSTANG
    Quote Originally Posted by tramp View Post
    hi ,
    happy fiddling
    tramp
    never had a problem with my choke plungers in over 4 years. They don't get used much mind.
    I had a couple of months of having to use the choke to get the bike started, then the battery died and had to be replaced since fitting the new battery It starts without the choke.
  1. Well it ain't the choke!
    Last Post: 13-05-09, 03:17 AM
  2. Why does my choke do this?
    Last Post: 17-11-08, 02:59 PM
  3. b*st*rd b*st*rd b*st*rd choke - AGAIN
    Last Post: 27-04-07, 09:19 AM
