Definately engine oil from large dia hose (stuck a pipecleaner up and all black wet oily also this pipe is shortest and other two have oil on outside of pipes). Scottoiler set ok. Fuel tank qtr full. Will remove cover clean front sprocket tomoz evening. Still the oil leak from filter area
. Newspaper under to access ammount. Could always divert engine breather horizontal under seat so exccess runs back to engine, its only a breather when all said and done. I would like to fix it without bothering Mr Honda. Dave
