Results 1 to 7 of 7
Thread: clutch lever handle
    Sep 2008
    mainland
    clutch lever handle
    Can the 700 owners please check the spell on their clutch handle.
    I don't mean the normal movement "pull in and let loose again" when shiffting gear ,but the spell up and down.
    Mine has since a long time about 1,5 cm movement up en down.
    Dealer says "its as tighten as possible" ,we checked the only other 700 in his shop witch also had some "up and down spell".
    If you other 700 owners have the same amount of movement i'll guess that this is normal.
    Otherwise i don't know if this could harm in any way the proper function on the clutch or cable in due time?.
    Enjoy
    Dogmatick's Avatar
    Dogmatick is offline Stop looking at my Member
    May 2009
    Wimbledon, London
    Re: clutch lever handle
    Thanks for this Grey, I've been thinking mine was loose but good to know it aint just me
    A
    XL700VA My first bike
    I think most levers move slightly. It is the tolerance, as long as it is not excessive.
    Bluff's Avatar
    Bluff is offline ???
    Aug 2009
    Just over there
    Just checked mine for you; about 1cm. I had never noticed before but i expect I will sleep soundly nonetheless
    Sep 2008
    mainland
    Stumpy ,just for the record ,while in the shop i also did try other bikes their clutches and some of them are indeed a little loose .Others where pretty tight ,but thats because they have a different construction.
    Bluff and Dogmatick ,if others can confirm the plus minus 1 cm than we can assume its normal for the 700 to have a loose clutch handle.
    Enjoy
    davedixon Guest
    You must take into account the length of the lever. If it moves 1cm at the lever end then the movement at the fulcrum point (where the bolt goes through) will be quite a bit smaller. Imagine your lever as being twice as long the movement would be horrendous but the fulcrum would still be the same. Mines just over 1cm, you have nothing to worry about. Just make sure you have about 10-20mm free play (measured at lever end) before clutch lever (on g/box casing) starts to move.Dave.
    ADE THE BLADE's Avatar
    Jan 2009
    up there !
    think you`ll find you would have far more clutch problems if it was too snug a fit....dont want a clutch lever stopping midway do we? never mind vertical `play`, concentrate on horizontal play ( as in clutch cable free play.)
  1. For Sale: AT/TA Clutch/Choke Lever and Brake Lever
    By AlanH in forum For Sale / Wanted
    Last Post: 22-06-09, 11:34 PM
  2. how does yours handle
    By Austin in forum Varadero
    Last Post: 17-03-09, 10:21 PM
  3. Clutch Lever
    By Keef in forum Dominator / FMX
    Last Post: 01-04-07, 08:24 AM
  4. wires on clutch lever
    By churches67 in forum Dominator / FMX
    Last Post: 25-03-07, 09:44 PM
  5. Clutch lever assembly wanted
    By squirrelciv in forum Dominator / FMX
    Last Post: 02-03-06, 06:34 PM
