Results 1 to 10 of 13
Thread: Can someone point me to a suitable feed for heated grips on a '98 TA?
    teriyakimonkey's Avatar
    teriyakimonkey is offline Senior Member
    Mar 2007
    London
    I've got some heated grips to fit in time for the winter.
    Not being too familiar with the TA can someone point me in the direction of a suitable feed to power the relay coil?
    Is it best to go straight to the battery for the power circuit?
    Thanks in advance.
    Re: Can someone point me to a suitable feed for heated grips on a '98 TA?
    I have heated grips fitted to mine.
    I am in the process of rewiring them to feed only when ignition is on.
    I am looking at splicing them into the fan circuit as the fan does not run very often in the winter.
    jarl's Avatar
    jarl is offline Senior Member
    Apr 2009
    Bath
    You have 2 choices. Either onto the fan as mentioned or to the battery through a relay. If you use a big relay (30A) then you can have multiple outputs; one to heated grips, one to a 12V socket, one to DRL's, etc, and also your heated grips and accesories will only come on if you turn the ignition on- I wired the relay to the sidelight to come on, others have used brake lights or you can piggy back anything that's on constantly when the ignition is on.
    Jim Davis's Avatar
    Jim Davis is offline Vendor and Supporter
    Apr 2009
    Japan
    I suggest using the rear brakelight connector for switching a relay. The input to the switch is powered only when the bike is on. The connector is easy to find, just behind the fuel tank rear and on the right side, near top of frame.
    Make sure you get the input wire, not the output. See your wiring diagram to make sure.
    One more thing, do not use a Scotchlock or that type of clamp on tap.
    Do not use the fan. You could use the hot wire to the fan's thermo switch though.
    trophydave's Avatar
    trophydave is offline Senior Member
    Feb 2007
    Nottingham
    Quote Originally Posted by Jim Davis View Post
    I would agree with that,it is how I wired mine up.
    Rust never sleeps
    ABC
    ABC is offline Senior Member
    Oct 2009
    somewhere
    You might like to consider heated gloves. They are way superior to heated grips because they warm the whole hand whilst heated grips leave the backs exposed. I bought mine years ago and have used them on a variety of bikes. My last bike, a BMW, came with heated grips but I rarely used them because the gloves are so much better.
    Quote Originally Posted by ABC View Post
    I have used both and find the grips the best so far.
    ABC
    Oct 2009
    somewhere
    I don't understand that. How can the grips, which heat only that part of your hand in contact, be better than the gloves?
    trophydave's Avatar
    Feb 2007
    Nottingham
    Grips are O.K. but the thing that I have found works best is a heated vest.They need not be expensive,mine is a DIY one that I have been using with no problems for years.
    Rust never sleeps
    I don't know why they are, but I found the grips better at keeping my hands warm.
    I may have something to do with the lack of fingers.
  1. Oxford Heated Grips vs Motrax Headed Grips
    By Wold Rider in forum Africa Twin
    Last Post: 13-12-08, 09:58 PM
  2. Heated Grips
    By Danielle in forum Transalp
    Last Post: 10-10-08, 10:04 AM
  3. Heated grips or not?
    Last Post: 25-07-08, 11:38 PM
  4. Heated grips...... at last :)
    By russh in forum Accessories
    Last Post: 18-11-06, 10:03 PM
  5. HEATED GRIPS
    Last Post: 07-05-06, 08:03 PM
