Results 1 to 7 of 7
Thread: clicking between 3 and 4K
    jarl's Avatar
    jarl is offline Senior Member
    Apr 2009
    Bath
    Recently my bike has started clicking between 3 and 4000 RPM. It seems to be coming from the front right of the bike. Recently did a bit of maintenance and fitted a stebel horn, checked the plugs and had the tank, etc, off to get at the air filter. Also recently replaced front hoses with braided items and had a quick poke of the front brakes whilst I was down there. The valves need doing and it's nearly the sound they make, just louder and only over a specific rev range, rather than what I'm used to valves sounding like.
    Everything seems tight and correctly on and the bike is running fine. Any idea's?
    Re: clicking between 3 and 4K
    Check the plug cap. it could be loose and arcing out at a specific range.
    holmfirth
    Could it be leaking compression from an untightened plug?
    ©-©'s Avatar
    ©-© is offline Xi dwejjaq member
    Sep 2008
    Middle©
    Can you hear the clicking between three-thousand and four-thousand rpm when the machine is stationary - or only when on the move?
    jarl's Avatar
    Apr 2009
    Bath
    It was both stationary and moving. Popped both HT leads off, put them back on and the noise has gone.
    holmfirth
    Quote Originally Posted by jarl View Post
    Looks like Stumpy was right.
    Quote Originally Posted by T ALP View Post
    Quite a shocker I know.
  1. Strange clicking noise
    By bikderdude2006 in forum Transalp
    Last Post: 22-01-09, 06:08 AM
  2. Clicking somewhere around the handlebars
    By Haynesemail in forum Transalp
    Last Post: 05-09-07, 07:26 AM
  3. clicking on Fuel pump Facet 40105, is it normal?
    By gemsx in forum Africa Twin
    Last Post: 24-08-07, 10:32 AM
  4. Strange clicking sound
    By rlkat in forum Transalp
    Last Post: 31-01-07, 01:16 PM
  5. Mysterious clicking?
    By markh in forum Africa Twin
    Last Post: 06-09-05, 11:38 AM
