Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: engine oil
    mad max is offline Member
    Apr 2009
    Ireland
    engine oil
    hi guys
    I have a 06 transalp 650 and i am about to do an oil change which oil would be best for this bike.
    Cheers.
    ADE THE BLADE's Avatar
    Jan 2009
    up there !
    Re: engine oil
    10w 40 semi synth bike oil.........dont forget a nice new filter..
    Re: engine oil
    I use Castrol GPS 10W-40 and have done for over 220,000 Honda V-twin miles (spread over 3 bikes).
    The only thing is, engine oil is starting to get as expensive as petrol nowadays.
    Apr 2009
    Ireland
    Re: engine oil
    thank for that mate. I have been using good quality oil but it was not semi senthic ,do you have any clutch slipping with the semi senthic.
    Cheers mate.
    Lutin's Avatar
    Galway
    Re: engine oil
    Not had any clutch slip with the Shell Advance VSX4 10w-40 semi-synth that I use in my '04 Transalp. Good stuff.
    And a new filter always helps.
    Re: engine oil
    Quote Originally Posted by mad max View Post
    Cheers mate.
    Never had a clutch slip on a bike yet, only ever used bike specific oil though.
    Apr 2009
    Ireland
    Re: engine oil
    thanks for that guys.
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    Re: engine oil
    hi mad max,
    you only get clutch slip :
    [a] when its knackered
    [b] when you`r a total plonker and put car based engine oil in
    tramp
    Re: engine oil
    I use Castrol GPS Semi sinthetic oil as purchased fron OPIE Oils and do not have a problem.
    dilly is offline Member
    Jul 2008
    Kent
    Re: engine oil
    I am using Guardian Rock Oil 10W40 semi synthetic with a K&N oil filter.
    Oil supplied from www.wemoto .com & the filter was bought on e-bay.
  1. What engine oil do you use?
    By Drawmer in forum Africa Twin
    Last Post: 28-05-11, 08:02 AM
  2. Getting that new engine look, HOW!!!
    By TRANSPORTER in forum XR
    Last Post: 26-03-09, 03:36 PM
  3. Engine cut
    By aliennative in forum Africa Twin
    Last Post: 13-11-08, 01:14 PM
  4. I need a new engine
    By sam h in forum Africa Twin
    Last Post: 26-01-07, 04:01 PM
