Results 1 to 6 of 6
Thread: Earth points on a transalp?
    jarl's Avatar
    jarl is offline Senior Member
    Apr 2009
    Bath
    I'm bored of running wiring all the way back to the -ve terminal of the battery. Where are the earth points on a tranny?
    Re: Earth points on a transalp?
    The engine mounts and the fairing mounts earth out most point on the frame will provide an earth point.
    jarl's Avatar
    Apr 2009
    Bath
    oooh, excellent. Looks like I can tidy everything up nicely then
    Thanks!
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    hi jarl,
    why all the earth points? what goodies are you fitting
    tramp
    jarl's Avatar
    Apr 2009
    Bath
    LED DRL's, 12v socket, stebel horn, alarm/immobiliser, heated grips (current ones seem to be on their way out). The usual, really
    shack's Avatar
    Jun 2007
    Devon knows why I'm so creamy
    I've found the handlebar clamp bolts being used to earth my heated grips
  1. 3 points...
    By yoashman in forum Chatter
    Last Post: 16-06-09, 05:34 PM
  2. Earth/Ground points
    Last Post: 11-05-09, 10:47 PM
  3. What on earth.....
    By Cie in forum Chatter
    Last Post: 30-06-06, 11:35 AM
  4. '91 TA Weak Points??
    By Steve T in forum Transalp
    Last Post: 22-03-06, 08:26 PM
  5. The Four Points of Ireland
    By Phoenix in forum Africa Twin
    Last Post: 08-07-04, 07:40 PM
