Results 1 to 7 of 7
Thread: touratech sump guard install instructions
    dropman is offline Member
    May 2009
    LV
    Hi. Recently got touratech sump guard (used) on ebay. Can someone give me install instructions for it? Or some photos or explanations how to mount lower part of guard to bike? There are two holes on lower part of guard, and I have no idea how to use them. Thanks.
    EDIT: bike is xl650v4
    markt is offline Junior Member
    Redhill, Surrey
    Re: touratech sump guard install instructions
    Found this on the Touratech website. Hopefully of some help.
    http://www.touratech.com/shops/008/d...73327abb1d9b10
    Cheers,
    Mark.
    largewayround's Avatar
    May 2008
    Aberdeen, Bonny Scotland
    Hi Mate
    On the lower part of the sump guard , under the engine, you have 2 holes , you can just see my bike which has the guard fitted,.
    There is 2 P clips, under the gear lever.. and brake lever on other side..
    These P/clips are large enough to go round the frame rails and attach with bolts to the holes in the sump guard.
    The P clips are rubber coated.. like this one ..
    If you have not got the clips, these easily available on internet or local car parts shop . Measure the diameter of the frame rails,. and get yourself a couple of stainless steel nuts and bolts .. sorted..
    If you need and more help , installing .. just shout .
    May 2009
    LV
    Thank you all. That is what I was looking for!
    One more question: Do you have some spacers on other mount points? I read in given link that there is also used some 3 and 4mm spacers.
    May 2008
    No Problem ..
    The spacers.. Yes mine came with those spacers..
    The spacers, go between sump guard and the attaching arms on each side .
    And the 3mm behind the front connecting point..
    If you can not get spacers. maybe some measured nuts ,, or SS washers would work..
    I also used SS fixings instead of supplied bolts..
    1. Remove old guard
    2. Offer up replacement if holes do not fit drill new ones
    3. If screws too long use hacksaw and cut to size
    4. No where to mount, then use Glue.
    5. Charge for excessive labour
    Bodge it & Run motors.
    May 2009
    LV
    Thanks. Now everything is clear.
    Love this forum
  1. Givi Engine Guard Fitting Instructions?
    By GavBrown in forum Transalp
    Last Post: 13-10-08, 10:25 PM
  2. what sump guard?
    By sweet pete in forum XR
    Last Post: 11-06-08, 10:45 AM
  3. Sump Guard - anyone else want one?
    By piguglyshandydrinker in forum Transalp
    Last Post: 16-02-08, 09:26 PM
  4. @ sump guard
    By stanbloke in forum Varadero
    Last Post: 06-08-07, 10:49 PM
  5. The sump guard
    Last Post: 08-11-04, 04:10 PM
