Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: TA 600 Valve clearances
    Warthog's Avatar
    Mar 2007
    Re: TA 600 Valve clearances
    Quote Originally Posted by Recycler View Post
    Did mine yesterday - but this is on a 650..
    I don't remember any major differences in doing the work and the 600 does not have all the emissions pipework on top of the cam covers - which helps.
    I was lucky. After 31,000 miles since I last checked them, they were all still spot on.
    Whether you do this job or not - get some grease on the timing cover threads or they seize solid;
    Great pictures!! That will cvome in handy when it's time to do them!
    Quote Originally Posted by jarl View Post
    Silly question, but will oil come out of the timing cover when I undo it?
    The oil will sit far lower in the sump. As long as the bike is upright, you should be fine...
    rlkat's Avatar
    rlkat is offline '99 Varadero 1000
    Oct 2005
    North Berwick
    I don't think oil is behind that side of the engine. It's only the clutch side and the central bit where the oil is.
    Don't quote me on that though.
    Rob
  4. #13
    As Jaqueslemac has found out on his AT.
    No oil came out of mine when I did them and that was on the sidestand.
  5. #14
    Recycler's Avatar
    Recycler is online now Pleb
    Cornwall
    No, the magneto (flywheel) is behind there - that's what you turn to get to top dead centre - it does not run in oil. The engine cover on the other side houses the clutch - that runs in lots of oil!
  1. Valve Clearances
    Last Post: 01-04-10, 04:28 PM
  2. slr valve clearances
    By starfazer in forum Dominator / FMX
    Last Post: 07-10-08, 09:12 AM
  3. SLR 650 Valve clearances ?
    By pelt in forum Dominator / FMX
    Last Post: 03-11-07, 01:55 AM
  4. Valve Clearances (Yen)
    Last Post: 22-04-07, 06:50 PM
  5. Valve clearances.
    By Chris J Barrett in forum Africa Twin
    Last Post: 14-06-05, 12:57 PM
