Results 1 to 3 of 3
Thread: Transalp XL600 Choke & Revs....
    Nige2009 is offline Junior Member
    Nov 2009
    Bradford on Ganges
    My 89 'alp starts OK on the choke, but the choke lever won't stay in the open position? Is this normal & if not is it anything to do with the main issue.
    I rev the bike & it revs up fine, the throttle snaps back fine, but the revs fall slowly, not like they should.
    If i waggle the choke cable it sends the revs nuts too.
    Help?
    moon's Avatar
    moon is offline luddite
    Mar 2005
    Auxerre, Burgundy
    Re: Transalp XL600 Choke & Revs....
    sounds to me like you need to lube everything that moves on the carbs, & then the choke cable too.
    but I ain't an expert (as you probably guessed from the technique "if it moves, lube it!")
    Safehouse in Burgundy
    piguglyshandydrinker's Avatar
    East Lancs....
    If the choke lever doesn't hold it's position, just tighten the pinch bolt a bit.
    Varying revs mean the choke/s are sticking, remove the assembly where it enters each carb, clean & lube - including the cable.
  1. would like XL600 Transalp plastics
    By skyrise in forum For Sale / Wanted
    Last Post: 08-08-08, 05:46 PM
  2. choke in but revs go down - what's going on?
    Last Post: 02-07-08, 08:57 PM
  3. Revs hanging up
    By bazzyj in forum Dominator / FMX
    Last Post: 04-05-08, 09:22 PM
  4. revs
    By ethel biscuit in forum Transalp
    Last Post: 11-08-06, 08:02 PM
  5. correct revs
    By nimrod in forum Africa Twin
    Last Post: 13-12-04, 01:43 PM
