Results 1 to 2 of 2
Thread: Chain jump problem
    Shayite Guest
    Chain jump problem
    The split link part of chain is not running smoothly over front sprocket when it gets there, it is jumping a little most noticable sub 30mph. Have checked wheel alignment, chain tension and even tried to press the plate further on to make a difference (difficult)
    Anyone have any other ideas?
    Recycler's Avatar
    Recycler is offline Pleb
    Cornwall
    Re: Chain jump problem
    Split link as in one with a C - clip?
    Is the chain worn? Pull it away from the back sprocket at the 3 o'clock position - if it lifts half way up a tooth it's had it. A worn - or too loose chain will make a rattly noise at low speed before engine power pulls it tight on the top run.
    What about the sprockets - still plenty of wear?
    Is the split link stiff? - move it to between the sprockets at the bottom and see how easily you can twist the link either side up and down - should be as easy as any other link.
    Personally, I wouldn't use a split link and always use a soft link - once it's joined properly it'll never undo.
  1. Anyone who says an XR650R can't jump....
    By UKRob in forum Ride Reports and Pictures
    Last Post: 11-10-09, 06:43 PM
  2. Chain/Sprokets PROBLEM in SYRIA!
    By Tybalt in forum Africa Twin
    Last Post: 05-12-08, 11:00 AM
  3. A hop, skip and a jump
    By lootch67 in forum Ride Reports and Pictures
    Last Post: 25-09-08, 02:10 PM
  4. Jump anyone?
    By Whealie in forum Chatter
    Last Post: 05-01-08, 10:09 PM
  5. Jump Starting
    By McVicar in forum Mechanical Advice
    Last Post: 21-10-06, 05:15 PM
