Results 1 to 10 of 16
Thread: T/A 650 main stand
    buzz is offline Junior Member
    Jul 2009
    Devon
    T/A 650 main stand
    Hi all , I need help ! i have just bought a second hand Main stand for my 650 transalp it has two springs and the main bolt ,before i start skinning my knuckles trying to fit it has anyone got some tips ? I await in hope can i take this opportunity to wish every one a super Christmas
    Re: T/A 650 main stand
    Positon the two springs and try using 2p pieces between the coils to stretch the spring then using pliers remove once in position.
    Jul 2009
    Devon
    Thanks StumpyFingers, thats my job tomorrow i hav`ent had a look at the under side just yet i presume that i will see where the springs fit ? thanks again
    Austin's Avatar
    GARSTANG
    I have never had sucess with the 2p thing - ends up bending the spring. I have done this three times now and each time did it with a short arno strap (luggage straps) and a short loop of strong paracord.
    Fit the spring to the stand, Para cord loop goes round the other end of the spring, arno strap goes through the loop and round the back wheel. This gives two options - big heave on the loose end of the arno strap will get the spring starting to stretch, then do a bit fine tuning to get approximatley aligned with the bracket. Depending on the angle you are pulling at you should be able to get a really good stretch. Then you can also turn the wheel by hand to get even more tension and get the alignment right to the bracket (assistant needed to put back brake on and hold it). Use a screwdriver (keep hands away) to push the spring towards the bracket and line up with the hole, then either ease off the arno strap 'til it fits or rotate the wheel back a touch. Dead easy
    Whatever you do, good luck.
    piguglyshandydrinker's Avatar
    East Lancs....
    I've done it once & that was enough.....
    Have you tried the 2p thing stumpy, like Austin says, didn't work for me either.
    I think that I errrm struggled, actually I can't remember how I did it now but GOOD LUCK (you'll need it.....)
    Jul 2009
    Devon
    Well I did it ! i tried the suggestions but no luck , managed to fit the springs using two screwdrivers a large phillips and a small spade one , i levered the large spring down to the spring holder and the used the small screwdriver to flip it over onto the clip and then used some cord to pull down the smaller spring onto the same spring holder( clip ) many thanks for your help and replys
    dogwheel is offline Senior Member
    Jan 2009
    worcestershire
    A mate fitted mine whilst I was getting over being poorly earlier this year. He used a lash up based on a length of Allthread (threaded rod) to fi some nuts, and bits out of the scrap bin, to make up a spring puller. I'll try to get more details after Christmas if you wish, (I don't really want to mither him today)
    I still can't find a way of removing the sidestand springs 'though, the coin trick nearly worked. Take care! They'll have your fingers if they can!
    All the best.
    timshap is offline Junior Member
    Dec 2009
    York
    I am about to fit a sw motech centre stand on the TA 650 but do not have a main spring as the stand was separate to the bike when bought.
    Does anyone know where I can get a new spring from?? I cant seem to see anything on the internet specifically for bikes. Bare in mind its double wound as well..
    Help........
    Jan 2009
    worcestershire
    Hi Tim?
    2 Suggestions,
    I've just Googled SW Motech and it shows a number of decent UK Dealers, I'd try them first.
    In today's VMCC Journal there is an ad from :
    Paul Savage 01527 521666(days) 01527 893151(eve/wkend)
    He's in Redditch, where all the world's best springmakers come from, and he really understands Springs and Bikes.
    Take care, and don't you need a special through bolt also? or have you already got that?
    Regards.
    sichroteph is offline Junior Member
    Apr 2010
    france
    Well nothing worked for me.
    I had no garage and only very weak string.
    Each time i tried to make a lever, the string broke or get stuck.
    I managed to do it that way, not very conventional but so damn easy, can be usefull to share :
    1) Attach both springs on the bike
    2) Attach the little one to the chain with some string
    3) Move the bike foreard until the spring is a good distance
    4) Put the spring to the stand
    5) Cut the string
    Repeat this steps for the bigger spring
    The procedure is like 10mn
  1. Main stand and price adjustments
    By Kjell Lindberg in forum Africa Twin
    Last Post: 26-03-09, 03:28 PM
  2. Side or Main stand ?
    By peelerfart in forum Mechanical Advice
    Last Post: 31-07-08, 09:39 PM
  3. Wemoto Main Stand
    By BuckarooBanzai in forum Transalp
    Last Post: 07-06-07, 05:04 PM
  4. Main Stand Question....
    By Ratrap in forum Africa Twin
    Last Post: 08-04-07, 08:54 PM
  5. main stand and crash bars
    By 4x4biker in forum Africa Twin
    Last Post: 09-12-06, 09:50 PM
